There is a rule that we should substract Audio Size from Total size to find out Final Size of a Video File on CD after convertion is done. How can I find out how large is Audio Size of a video file when I convert the video file by Virtual Dub (two pass converting), because I want to know the final size of the file on CD?
If the audio is already embedded within the file...then you already know the final size.
Google is your Friend -
Also the size is more than just audio + video. There is also container overhead.
Audio streams are either LPCM, CBR compressed or VBR compressed.
If they're VBR, you won't know until you can figure out the total length and the AVERAGE bitrate.
If they're CBR or LPCM, it's easy:
Filesize = Length of time x Bitrate
So, for example, 20.5 minutes of Audio CD LPCM data (headerless WAV type) is ~1378kbps * 1230 sec = ~206MB.
-or-
98 minutes of 384kbps CBR-compressed 5.1/AC3 is 384kbps * 5880sec. = ~276MB.
Help? No size is shown for video or audio file.
By thezanny in forum Video ConversionReplies: 5Last Post: 10th May 2011, 04:28 -
Audio File Size Calculator
By onesikgypo in forum AudioReplies: 1Last Post: 13th Sep 2010, 09:14 -
audio out of sync / file size reduction
By rancid in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jan 2009, 06:55 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 22:58 -
Strange audio size issue.
By mijman in forum DVD RippingReplies: 1Last Post: 16th Jan 2008, 07:42
