Hello.
I have been using dvd shrink for a long time now and it has work fine until now.
The problem maybe doesn´t even concern dvd shrink.
Dvd shrink does all the things right and i burn it with Nero 6.6.0.8 and everything seems to go right.
Then when i put the copied dvd into my dvdplayer the picture freezes up about say 30 to 60 minutes into the movie and its unwatchable.
Im burning with DVD-R disc from TDK. And also on the slowest burningspeed.
Oh and one more thing. I tried to watch the copy on my computer. It freezes up there to. So it must be somthing with Dvd shrink?
So what can be the problem? Its just recently i have had these problems.
Costing me some empty disc and its starting to piss me off when they won´t work.
could be a problem with the .IFO files ... open the VIDEO_TS.IFO with ifoedit and click on the 'GET VTS SECTORS' button ... click yes /ok until its finished ... (if no changes are made then they were ok in the first place and this isn't the problem) close ifoedit ... try playing the dvd files from your hdd (using power dvd or similar) if they work ok burn them and see if that cures the problem .... if not then maybe its bad media ... try another disk brand
Try playing the DVD layout before burning -- if it plays fine, then the problem is in your burning, as in something with Nero, your blank media etc...
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
