This isnt a problem with svcd2dvd but thought someone here might be able to advise.
This was fine before but now the following happens.
Most xvids or divxs that a click on crashes my explorer and all my windows shut down if i do get one to play it plays in slow motion, as said it never used to do this does it mean i have a corrupt codec or something?
do i need to uninstall all my codecs and install somke new ones and if so what do people suggest?
btw this has also happened in svcd2dvd when i tell it to play some of the files svcd2dvd shuts down.
As stated above when i try and view on PC (i.e Media Player) it crashes Explorere most of the time
I see. Didn't read the post properly!.... Sounds like a codec problem. I would remove all & start again, just adding what you need.... Maybe someone can advise on what you should install - i have no idea.
MeGUI crashing
By socrates in forum Video ConversionReplies: 0Last Post: 10th May 2011, 04:49 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 14:29 -
My Avidemux Is Crashing
By bigman70 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 11:54 -
MPV crashing
By SignedupGuest in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 15:38 -
system crashing
By alintatoc in forum Newbie / General discussionsReplies: 11Last Post: 6th Apr 2009, 08:03
