Results 1 to 10 of 10
    Dec 2005
    my orginal file has good audio sync, but when i convert my rvm file the sync isnt good at all....anyway to fix this?
    Dec 2005
    if i burn it, will the sync work again?
    USA
    Probably not.
    Two common types of sync problems.
    Sync is offset by the same amount throughout the video. You add or subtract a delay in the audio track.
    The video gradually loses sync during the video. The audio length does not match the video length. You shorten or lengthen the audio or the video to match the lengths.
    Depending on the format you have converted to, a couple of programs to help with sync adjustments are SyncView and Hypercube Time Stretcher.
    Otherwise it is just trial and error.
    Dec 2005
    my file is rvmb...
    Nov 2002
    Another thing to note: it COULD just be the darn player that's losing sync, instead of your file.
    For example, I have have a very low-spec computer (400 MHz, really) and thus I have problems often playing some of the biggest videos, like DIVX5 in hi res, and so on. Even BSPlayer often loses sync when playing DIVX or XVID videos. VLC doesn't have such problems, but it's compatible with fewer formats/codecs.
    I would check the file lengths and such and try seek back and forth to make sure that you really are losing sync in the FILE, instead of in the player. If you are only losing sync in the player, than if you jump ahead the sync should be maintained.
    Dec 2005
    no, im losing sync in the converted file
    the orginal file is fine, my guess is cause there are 1 sec freezes in certain parts. ( but after that the audio is fine) But when u encode it, i get back sync cuz of those delay( thats my guess)..would video fixer fix this?
    Dec 2005
    Portugal
    I have a similar problem with some films... but not all.
    When i use the bsplayer it's perfect with the sync but when i try to burn in dvd (with nero), the video is not sync with audio. I think that the problem is with the video because the subtitles are correct with the audio.
    Anyone knows the solution?
    Thanks in advance...
    Dec 2005
    Portugal
    it happens again with another film. Transporter 2.
    When i see it with bs player it's perfect.
    But when converted to dvd the sound is out of sync with the video.
    Please help...
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    plimplimplim : You can use your original DVD to get a good backup. If you don't own this film on DVD, you should not be discussing it here
    Read my blog here.
    Feb 2004
    Australia
    From what I read in super ... it may have the ability to convert that rmvb to a more suitable , and editable format .
