Hello,
I've been experimenting with a variety of different formats... I'm lucky that my DVD player will play VCD, SVCD, DVD, and even mini-DVD. It's a SAMPO 611, I recommend it. At $109 it's a deal. Plays NTSC and PAL too.
Now... I've encoded the same home movie (from Hi8->iMovie->MOV->TMPEnc v2.5), once for SVCD (strict compliance), the other for DVD.
Each is at 720x480, with some cropping (16 pixels on all borders). As I say, same source material.
My results are that the mini-DVD is *much* worse quality than the SVCD... at least IMHO. On the DVD, edges near any kind of motion (whether the camera or subject) exhibit lots of artifacts, blockiness, etc.
Very disappointing. I would have thought with 3x bandwith the "DVD" would be far superior.
Any thoughts?
Thanks,
ZX80
TMPGenc is not exactly "state of the art". It is very good, surely, but there is no magic solution for encoding: processor power and time. So you must use a better encoder (like CinemaCraft) and if space is a problem, use variable bitrate with no less than 3 passes. 4 is best, 5 is an exageration. Also, the edges have artifacts almost everytime. Take a closer look at a DVD movie edges...
Well.... I have discovered that the problem lies not with TMPGEnc, but rather with iMovie.
If I take my original captured file and export from iMovie, it introduces blockiness.
If I import the DV clip file from iMovie into QT Pro, the blockiness is not present.
Saving that clip as a DV format AVI gives MUCH better results from MPEG encoding...
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 15:05 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
