  1. Hi everybody, i wanted to pose some questions about DVD players functioning. It happens that I have started to put all my music onto dvd’s with proper software. I begin not to have enough space to condition them. I only have Classical Music. The question is when i record a piano concert, for instance, i record all the “musical piece” as a single entity, if you know what i mean. But the concerto itself is divided in three movements. When i want to hear the second one i have to hear all the concert from the very beginning. Is there any dvd player that allows me to forward in a way that i can start to hear where I want to, not having to hear all the “musical piece”. Or the problem lays on the way i record the music. Do I have to start to divide even the movements inside the piano concerts.
    Thanks to all,
    J. Silva
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    With the music recorded as a single entity, all players will only see it as 1 song. I would suggest recording the three movements as seperate entities, then you can skip to the next part.
    Google is your Friend
