Hi! I got a .srt subtitle file that i want to add in the project. I use DVDLab 1.3. I do i import it to the movie in dvdlab. I tried to use vobsub when i encoded the avi file to m2v, but it wont work. Vobsub dont start. I got the avi and srt in same dir and same name. How do I do? Thank you for any help
Encode video to DVD specs mpg.
Load it in DVD-Lab Pro.
Load the .srt in DVD-Lab Pro.
Author.
Or:
Substitute DVD-Lab Pro for DVDAuthorGUI.
Or: (for permanent subs)
Load AVI in VirtualDub
Add the .srt using the TextSub filter
Frameserve to encoder and encode to DVD specs mpg.
Load mpg in DVD-Lab
Author
Or:
Use AviSynth instead of VirtualDub.
/Mats -
DVD-Lab (non Pro) doesn't do subtitles.
/Mats -
mats.hogberg gave a few excellant options, but if you must do your layout in DVDLab, convert your .srt subs to .sup, create a separate DVD layout using something like muxman that includes the subs, then use Vobblanker to replace the title using the version with subs but sticking with your menu and such from DVDLab. There's guides here on specifics.
At their web site: http://www.mediachance.com/
...and don't hijack old threads - start a new thread for a new question.
/Mats
How to add Vietnamese subtitle ??
By caube in forum SubtitleReplies: 31Last Post: 17th Jan 2011, 18:16 -
import chinese subtitle to dvdlab pro
By pcb in forum SubtitleReplies: 1Last Post: 18th Dec 2010, 12:02 -
DVDlab Pro subtitle color wrong after compile
By nbarzgar in forum SubtitleReplies: 1Last Post: 9th Jun 2009, 10:29 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37
