I have an .mpg file that's 63MB, for less than two minutes of video. How can I turn that into a ~5MB or less file without making it tiny or grainy? I know it's possible... thatvideosite.com, for example, has lots of 5MB or so files that are a couple of minutes in length.
I need info about free software... I just want to convert a couple of little videos now and then for my own amusement, not for any kind of commercial use. I would also like to wind up with a format that is just going to play in a browsewr, hopefully regardless of which browser or platform. I suppose Quicktime is a good format, but can I do that with free software? What about WMV? I know the Windows Media Encoder won't work with MPEG2 for whatever reason...
Results 1 to 13 of 13
Try Windows movie maker, I have loaded MPEG-2 files in that before. And save out to WMV
Is there a way to just download Movie Maker? I don't want to turn on Automatic updates, and I can't install SP2. I just want the installation files for it with no nonsense
don't you want automatic updates and additional security patches for your legitimate copy of windows xp??????
Hell no.Originally Posted by greymalkin"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
If you are running XP, even service pack 1, you should have Windows Movie Maker installed by default. It normally lives under Accessories. If not, download WMM2 from the microsoft website.
Try this program called Super It can do what you want. I use it to convert to a format for use on a cell phone.
http://www.erightsoft.com/home.html
This is what it can do
# drag & drop any VIDEO file and EXTRACT the AUDIO part by converting it to
mp2, mp3, ac3, aac & amr_nb (the last 2 are playable on Nokia) format.
# convert any type of video <--> to your favorite PocketPC or Mobile phone 3gp/3g2 format (or vice versa).
# convert Flash containing FLV video to any other format.
# convert RealMedia files to any other format.
# convert QuickTime files to any other format.
# convert Windows Media Files (WMV, WMA) to any other format.
# convert AviSynth script files (.avs) to any other video format. (Recommended when direct file conversion fails)
# convert AVI files to <--> any other video format (or vice versa).
# convert ASF files to <--> any other video format (or vice versa).
# convert DivX / Xvid files to <--> any other video format (or vice versa).
# convert MOV files to <--> any other video format (or vice versa).
# convert MP4 files to <--> any other video format (or vice versa).
# convert MPG files to <--> any other video format (or vice versa).
# convert OGG files to <--> any other video format (or vice versa).
# convert VOB files to <--> any other video format (or vice versa).
# AutoMode to convert any type of video to VCD, SVCD, DVD.
# Play all of the above!"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
I found the executable for 1.1.something, but it won't open .mpg filesOriginally Posted by Richard_G
How? Where?If not, download WMM2 from the microsoft website.
I can't install SP2. -
Why should you want to install SP2? Go to the Microsoft site and do a search for Windows Movie Maker, version 2 is the current version and is the default version for download.
I have Windows Media Encoder version 9 loaded on this machine, running Windows XP SP1 and it opens and converts MPEG2 files. Why you think that Media Encoder won't work with MPEG2 files I don't know because it does. Maybe Version 9 isn't the standard version and I downloaded and installed that from Microsoft at some point in the past. Try it and see. -
STOIK won't read MPG, but VirtualDub should be able to turn that into WMV or AVI easily with some serious encoding.
How do I turn a video file 'right-side-up' AND SAVE IT?
By McSplufer in forum Newbie / General discussionsReplies: 8Last Post: 1st Dec 2011, 10:16 -
How to turn all the video files into one title in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 08:11 -
Video Clip Comparisons...my turn!
By ministry88 in forum RestorationReplies: 5Last Post: 26th Jun 2009, 19:50 -
how do i turn video from landscape to portrait
By andyod in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2009, 09:58 -
Turn many small video DVDs to one standard size DVD
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 30th Mar 2008, 18:57
