i go to the System Config. Utility thru msconfig. I click the StartUp tab to see what programs are used during startup. I have unchecked some programs that i know i dont need to run, but ihave no idea about. see if you can tell to leave checked or remove: (HP pavilion laptop)
1. programfiles/ati technologies/ati conrol panel\atiptaxx.exe
2. programfiles\hpq\notebookutilities\hptasks.exe
3. programfiles\hpq\one-touch\one-touch.exe
4. programfiles\synaptics\syntp\syntplpr.exe
5. \synaptics\syntp\syntpenh.exe
6. carpserv.exe
7. programfiles\hp\hpcoretech\hpcmpmgr.exe
8. programfiles\quickime\qttask.exe -atboottime
9. %systemroot%\system32\dumprep 0 -k
10. programfiles\hp\hpsoftwareupdate\hpwuschd2.exe
11. progra~1\common~1\adobe\calibr~1\adobeg~1.exe
can any of these be removed?
you can uncheck 2,7,8,9,10,11
those are off the top of my head you can check them against this database
http://www.bleepingcomputer.com/startups/
No POST during startup
By mysts in forum ComputerReplies: 5Last Post: 25th Oct 2011, 01:47 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
question about different OCR (optical character recogni) programs
By jimdagys in forum SubtitleReplies: 3Last Post: 19th Dec 2007, 18:31 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 05:14 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 18:30
