Hello. This may be a simple question to answer but I'm quite a newbie at building my own PCs so please bear with me.
Can I attach a slave IDE hard drive to the same IDE cable that has the DVD burner set on the master? I can see the grey connector for slave but I'm wondering if this will work OK with my PC. Thanks...
Results 1 to 9 of 9
Yes. Set the HD jumper to 'slave'. I would normally put the HD in the master position and the DVD as slave, but either way would work.
iam sure it will work but that may not be the best way to do it. i always keep my hds on the same channel as master, slave and other drives on secondary channel as master,slave. of course it gets more complicated the more drives you have. wait for other people to answer the post.
Or... just install them on separate IDE channels (if you have more than one) as masters. I always install my hard disks on one (primary IDE channel) and my optical drives on the other (secondary IDE channel).
Thanks for the quick replies. The problem is the drive was a present and is Ultra ATA not Serial ATA which my motherboard prefers. So it looks like the only option is to connect it to the DVD burner IDE cable because this cable's slave connector won't reach to the floppy drive to combine the DVD burner and floppy on the same cable. Howver, it seems this setup isn't the best. nt what way will performance suffer?
I don't have enough IDE slots on the MOBO basically as this new drive is my fourth HD in this case. -
Floppy drive on the same ide cable as DVD??????????? I've never heard of a floppy cable being able to connect on a optical drive like a DVD burner.Originally Posted by dastott
To settle your situation just buy a PCI CONTROLLER CARD then hook up all your hard drives to it. That way you'll have your mobo IDE controllers available. -
I would just connect to new drive to the slave position on the IDE cable as I mentioned. Most newer motherboards can handle mixed speed drives on the same cable with very little loss in speed to either.
What do have to lose anyway? If it doesn't work the way you want, try something different. But I think you will have no problems. The alternative is to change all your cables around or do what budz mentioned and add another PCI IDE controller.
Mine works fine that way.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate!
Connecting SATA hard drive in IDE PC
By alegator in forum ComputerReplies: 17Last Post: 13th Apr 2010, 15:00 -
Using a CF flash card as a PC internal IDE hard drive
By alegator in forum ComputerReplies: 4Last Post: 9th Mar 2010, 17:48 -
Using Laptop (IDE) Hard Drive in New Desktop?
By ron spencer in forum ComputerReplies: 3Last Post: 30th Jun 2009, 14:21 -
DVD Player With IDE Drive
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2008, 16:44 -
About IDE to USB adapter cable
By AusTaylor in forum ComputerReplies: 7Last Post: 4th Feb 2008, 01:18
