How to transfer my 5 VHS tapes shows to the computer PC or DVD the cheapers way? I don want to convert it in the converter shops its so expensive too. 1 tape to DVD= S$12.
I had check there are alot converter which is expensive but is there any cheaper recommand and good quality one, below $100 .. most of it is $299++ so expensive I want cheap stuff and good one!Can any one tell me!
Results 1 to 15 of 15
Starting from scratch or with nothing at all, 5 tapes at $12 each is only $60. I don't know of a much easier or cheaper way. The next option I guess would depend if you had or could borrow a camcorder with pass thru and dump it into your PC. From there the future is wide open
IS IT SUPPOSED TO SMOKE LIKE THAT? -
Originally Posted by canadateck
WOW! I haven't looked,but are there actually working DVD recorders at or under $100? (I don't get out much)IS IT SUPPOSED TO SMOKE LIKE THAT? -
Cheap DVD recorder and a even cheaper VHS recorder plus a scart lead..........
Oscar. -
Originally Posted by ZAPPER
Got one at Wal-Mart for 89$.
It works sometimes :P -
My apologies, and again, Wow! time is really slipping by me.
One thing that wont change is,You get what you pay for.Originally Posted by ZAPPER
Only if you are lucky!
The thing that I was thinking is that if there are units that cheap, then there ought to be some price drops on the better units or at least fuller featured units at a fairer price than I was thinking. Interesting, I may have to look into this a bit more now.IS IT SUPPOSED TO SMOKE LIKE THAT? -
ok. Do anyone know is there any connector cable or ports that can from VHS system to PC?
camcorder is it = digital camera ?Originally Posted by ZAPPER
how do I can use it pass thru and dump it into pc?
You need a capture card/device. Look to the left under "Lists" for "Capture Cards"ok. Do anyone know is there any connector cable or ports that can from VHS system to PC?
No. You need a digital Camcorder that will convert analog to digital and forward the digital signal to a USB2 or Firewire (preferred) port.camcorder is it = digital camera ?
That will depend on the make/model of Camcorder you use. The general process is to connect the analog outputs from the VCR to the analog inputs to the Camcorder, connect the iLink/firewire port on the Camcorder to the firewire port on the computer. Then use a "capture" software, such as WinDV. Press play on the VCR and Capture on the software. This will put the video on the hard-drive in DV-AVI format (approx 13.5 gig ber hour). From there you edit and encode to your hearts content.how do I can use it pass thru and dump it into pc?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
gadgetguy thank you alots!
I have a digital camcorder and Im trying to find how to use it! Now I think I also need to have a good card! any standard recommand of Capture Cards ! 8) or cheap cards!
Does anyone know about firewire? I don know how much is it
and how to install it into PC! If can, I think I will choose firewire to transfer VHS player to PC with firewire, is that possible?
Cost rise with firewire (of course, if you have a camera that converts to dv, then you only need a DV in on your PC...)
The cheapest way to capture VHS is with a cheap BT8xx based card. Second hand cost 10 - 20 Euros those days. You also need software to capture, convert, author and burn your projects, that also costs. Freeware solutions do exist, but: They are complicated and need time to learn
When you buy a capture card, it may has software to use. Usually it low class but in your case it might work
If you consider all the options, the best solution in your case, is a DVD Standalone recorder. Easy, fast (realtime) and with great picture quality.
And you can use it later for recording events from TVLa Linea by Osvaldo Cavandoli
Transfer of real bad tape to pc and restore
By mammo1789 in forum RestorationReplies: 96Last Post: 9th Mar 2012, 22:38 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Can this machine transfer from tape to disc?
By Janowski in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 13:23 -
DCR-HC42 Transfer Still Images from Tape
By MichaelRD in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 22:09 -
DV tape damage during transfer
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd May 2008, 21:03
