    Dec 2005
    Germany
    Ok, I know it is not the optimal solution to do that but since I won't do that so often I don't want to buy any software and I think it should work somehow in the way I want to that.
    I've got two movies/clips (nothing copyright protected I promise - just selfmade shortclips with multiple audio streams) that I put via IfoEdit DVDAuthoring into two different VIDEO_TS directories...
    Now I want to create a simple menu so that I can choose between these two movies (no need to select the audio streams just get the movies started)...
    My idea was the following:
    With an old version of Ulead DVDWorkshop (was in a magazine) I have created a menu and linked it with two dummy videos (0,1s black 28kb) and created a third video_ts dir.
    Now I would like to do the following in IfoEdit:
    (1) Rename the vts_01 from the two movies into vts_02 and vts_03 in the menu directory
    (2) Add these movies to the video_ts files of the menu
    (3) Change the link of the Menu from the Dummy video (Title 1&2 from vts_01) to the two movies (Title1 of vts_02 and vts_03)
    But especially (3) is quite tricky since I cannot find where it is saved to which title which Button links.
    Can you help me with that?
    Btw: My version of DVD Workshop cannot work with multiple audio streams that why I cannot do everything with it.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You're really doing this the hard way!
    Get TMPGEnc DVD Author (free 30 day trial) or DVDAuthorGUI or GUI for DVDAuthor (both free) - with any of those, a 2 movie DVD with a simple "Select movie" menu is a breeze - specially with TDA.
    /Mats
    Dec 2005
    Germany
    And how, if I want to do it the hard way?
    I can't believe that its so difficult. I've merged the DVD's together without any problem. I just need a line which says (CallSS VMGM) Call VMG PGC: 1 [Resume Cell: 1] or something similar and change it into (CallSS VMGM) Call VMG PGC: 2 [Resume Cell: 1]. That's it.
    Where are the commands of the Root-Menu saved???
    Nov 2005
    Using VobBlanker you can replace the vts_1, vts_2 vobs etc from your original dummy with ifoedit created vobs -- there's a few guides here at videohelp.com. I'm not sure how well it will work however using dummy files -- I normally create 1 layout with menues, create separate layouts in muxman for each title, then replace the vobs with VobBlanker to add graphic format subs, pretty much following the guides I mentioned. You might want to try that route, using your U-Lead app to do the menu stuff.
    If you want to play with the ifo's directly, then I'd suggest trying pgcedit.
    Dec 2005
    Germany
    Thanks. PGCEdit did the job.
    Question solved.
