For the last 4 days i have been trying to put movies on my ipod video. I have had no luck and am about to throw my ipod in the trash seeing as the video aspect was the mane feature that attracted me to get it yet i cant get it to frikken work. I have tried programs such as DVD Shrink, DVD Decrypter and DVDx. I have been using these guides [/url]http://www.videora.com/en-us/Converter/guides.html and http://www.engadget.com/2005/10/14/how-to-convert-a-dvd-for-your-ipod-with-video-in-windows/[url] When i make an image i use IFO. Is this why its not working? I tried ISO but i dont know jack about DVD ripping/converting. Whats the difference between IFO and ISO?
After i ripped and made the image i use Videora and convert it to the Mpeg-4. When it gets to 100% it doesnt say complete and the time remaing becomes negative which is weird. Then im only able to abort or Exit the program. Finally i go the the videoras video folder to get the the converted movie but when i click it i get, "Error -2048:this files is not a movie?" I cant even put it into Itunes. Why is this? What am i doing wrong? Do i need some other program? Please i really need this figured out.
Thank You
Hi i'd like to recommend you use this DVD to ipod video converter suite,You can download from LINK REMOVED if you like, good luck!
NO Spam
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
Try this program called #1 dvd Ripper. It will rip to a VCD file which is good enough for a small Ipod screen. The resulting file would be less than 1 gig I assume. I think Mpeg 4 is overkill for that size screen, and the file would take over the Ipod.
http://www.dvdtox.com/"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Originally Posted by gnslinger"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 06:58 -
Putting More Than One Movie On A DVD
By swordsman in forum Authoring (DVD)Replies: 1Last Post: 19th Sep 2007, 12:11 -
IPod nano with video and IPod touch
By SingSing in forum Latest Video NewsReplies: 0Last Post: 6th Sep 2007, 10:11 -
putting a video on to your iPod using iPodifier
By patrick_jimmy in forum Video ConversionReplies: 0Last Post: 26th Aug 2007, 05:26 -
putting an mp4 movie on to a DVD.
By patrick_jimmy in forum Video ConversionReplies: 12Last Post: 20th Aug 2007, 01:49
