When i tried to convert a cue file (with a bin file in the same directory) to mpg using VCDGEAR it converted but the file was 0KB. However, using VCDGEAR just 1 week ago on the same file it converted correctly (i had to delete because of space). So when i extracted the bin file using isobuster to mpg it worked but then when i tried to play it said error downloading codec.
It is a divx file. I think that this is not working because i changed my divx codec. I previously had 4.01 but that did not work with TMPGEnc when trying to convert an avi file (different one). So i installed 4.12...that did not work so i uninstalled it, installed 3.xx and then installed 4.12 again. this time the avi to mpg conversion worked, but now when i tried to play other divx files they did not work. So i uninstalled (well at least i think i did) everything and installed 4.01 again...and some divx files work and some dont (the ones that dont either dont play or just get only sound when playing).
Can anyone help me out?
THANKS
Results 1 to 1 of 1
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
