version 6.4.8.4 plays ogg and ogm files fine when ogg direct show filter 0.9.9.5 is installed
just got the new media player classic 6.4.8.7 and they wont play even after reinstalling the direct show filter
i dont think i did anything to the options in my old version of media player classic to get them to work
any ideas ?
and its not due to a an incomplete download or anything like that as the problem was there with both the official download and the one released with quicktime and realplayer alternatives
your settings should have been retained (I think). Did you overwrite your older version? or place the new version of the file in a different directory?
Go into View->Options and make sure that the checkbox for Ogg is cleared under Source Filters.
You could also try going back to the older version of MPC, if you no longer have it, you can get it at sourceforge.net, here is a Link
Do you get any specific errors?Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
i still have the old version in a different folder and it plays them fine
the new version just displays a blank window
will try some of the other suggestions when i get home
thanks guys -
Originally Posted by hhhhbk
Newer version just shows a black screen.
So i am using a older version at the moment... -
thanks skith
works perfectly
now to see if i can do something to get it playing asx asf files using a similar method
Media Player Classic can't play TS files
By Mylo in forum Software PlayingReplies: 14Last Post: 8th Mar 2012, 04:26 -
Media Player Classic can no play DivX files
By siluet in forum Software PlayingReplies: 6Last Post: 30th Sep 2008, 15:46 -
Media Player Classic and subtitles inside TS files
By boulder in forum SubtitleReplies: 2Last Post: 19th Sep 2008, 16:55 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player Classic buffering some rm files
By JackPollack in forum Software PlayingReplies: 4Last Post: 20th Aug 2007, 15:15
