The quetion is in the title
I don't know an easy or definite way, which is why I waited for someone else to reply.
My 1st guess would be to create two DVD titles, then put them together in a DVD layout where the end action of the first title is to play the 2nd. You'd probably need to use an authoring app, though not necessarily create any menus, and split your video where the subs split.
Or you might use subrip to OCR both sup files to text based, join those in something like subtool, then check your timing, particularly at the join, using subtitle workshop. -
Bump.
Is there any way to do this yet? I've searched and not found anything. Subtitle Workshop does not appear to support sup files, and joining them with 'copy /b ...' causes overlap as the timestamps in the second sup are relative to the second evo it's coming from, not the title overall.
Thanks.
Edit: After some more research I believe I may be talking about a different sup format than the original poster, but the question is still the same
The sups I am working with are coming from an HD-DVD.
I am having the same difficulty but thought that Subtitle Creator had the answer as it is supposed to be able to join subtitle files and does make any limitation to binary files in the manual. However I have tried all the methods that I can think of but so far without success. I would be pleased if anyone can detail the exact procedure to join subtitles in Subtitle Creator whether they be text files (SRT) or Binary files (SUP). Look forward to any help in this matter.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
join MZ TS files together
By dude905 in forum Blu-ray RippingReplies: 8Last Post: 3rd Apr 2011, 21:48 -
2 movie files, 2 sub files. Need to join them into one
By andre477 in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 21:03 -
How to Join 2 Ac-3 files
By Cunhambebe in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2008, 20:31 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
