  1. Forgive my ignorance as I'm used to using a dozen programs to do such jobs, however I am looking for something absolutely simple for my computer challenged friend that wants the same job done but with a far smaller step process. What would be the best software in your opinion that would be able to capture a DV video via firewire from a DV camcorder, convert it and create a DVD. It does't have to burn it but as long as it's already in Mpeg2 format I think my friend shouldn't have any problems since a tool like Tmpgenc DVD Author would do the rest.
    Thanks for the help.
    May 2003
    Peterborough, England
    I installed the 30 day free trial of Ulead DVD Moviefactory for my wife to use. She managed to transfer the footage over Firewire from her Canon MiniDV camcorder, trim the ends off clips, create a menu and burn it to a DVDR. All on her own with no help from me or our daughter.
    That has got to be the best advert for the software possible as normally she only ever uses Word (and treats that as an electronic typewriter!). It's cheap to buy too.
  3. Going Mad TheFamilyMan's Avatar
    Jan 2004
    south SF bay area, CA USA
    I'll also recommend ulead dvd moviefactory. It is a well integrated, all-in-one DV camcorder to TV watchable DVD disk application that is easy to use. I use it for authoring and occasionally for burning. I plan on using its capture capability when I finally get a DV camcorder. Its MPEG encoder is adequate but definately not top rate.
    Usually long gone and forgotten
    Apr 2004
    Miskatonic U
    If they are that challenged or pressed for time, buy a DVD Recoder with firewire input instead.
    Read my blog here.
  5. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    VSO DivXToDVD will do it.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
