The pictures above show the problems that occured while i was trying to compile my dvd with dvd lab pro. In my last topic i was instructed to close all programs while compiling the dvd. I did this and this same problem occured. Also, as you can see the progress of compilation states that it is done in the second picture. However, it hasn't even finished muxing the dvd. Do you think i should uninstall and reinstall dvd lab pro? Or is there something else i can do? Should i change where im saving my temporary files? I really do not know what to do and i have been trying to figure this out for days. If someone can help that would be greatly appreciated.
Closed Thread
Better try to find an answer at the Forum devoted to DVD Lab (think it is called MBForum)
Please do not cross post.
One topic is enough.
https://forum.videohelp.com/viewtopic.php?t=288397&highlight=
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 22:02 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 08:57 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 03:11 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 02:12 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00
