    Dec 2005
    I've been running SVCD2DVD for about a year now with no problems..........Until recently. Now when I start SVCD2DVD it crashes straight away. I think it maybe related to the installation of some new codecs (FFDShow) their icon pops up in a system bar and then disappears after the crash. I have tried to roll the codecs back and this hasn't resolved the problem. I had monitored the crash and got a log of the error.
    I have only attached the first 10 lines of the log, as it is very long: I hope somebody can help. I can post the complete log if that would help. Please advise
    additional: I had the problem before I upgraded to the latest version. After upgrade I had the same problem. I have recently installed new hardware. Graphics Card: Nvidia Geforce 6600 GT. Could this be the problem??:
    SVCD2DVD.exe 2.0.2146.38069 caused exception C0000094 at address 6FCDC64F (Base: 400000)
    Registers:
    EAX=00183F38 EBX=0012EB1C ECX=0012ED98 EDX=7C90EB94 ESI=00000000
    EDI=7FFDF000 EBP=0012EB90 ESP=0012EAF4 EIP=7C90EB94 FLAGS=00000246
    CS=001B DS=0023 SS=0023 ES=0023 FS=003B GS=0000
    FPU stack:
    3FFF8000000000000000 3FFF8000000000000000 3FFF8000000000000000
    00000000000000000000 00000000000000000000 00000000000000000000
    FFFF00000000FFD2F000 FFFF0000000032044800 SW=4000 CW=037F
    Stack dump:
    0012EAF4 7C90E9AB 7C8094F2 00000002 0012EB1C ||....
    0012EB04 00000001 00000000 0012EB50 00000000 .......P.....
    0012EB14 00000002 00000000 00000210 00000028 .........(...
    0012EB24 009024C0 7FFDE000 00000002 0012EB5C $.....\.
    0012EB34 77D49402 0012EBB0 00000014 00000001 w.......
    0012EB44 00000000 00000000 00000010 FF676980 ...........ig
    0012EB54 FFFFFFFF 00000003 7FFDF000 7FFDE000 .....
    0012EB64 00000003 0012EB50 0012EB1C 0012EBE4 ...P...
    0012EB74 00000002 0012EB10 00000000 0012F218 .........
    0012EB84 7C8399F3 7C809590 00000000 0012EBEC ||.....
    Dec 2005
    Addendum to my previous link. When I describe SVCD2DVD as crashing, it falls over. i.e closes immediately.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    First thing to try is reinstall .Net 1.1 and .Net 1.1SP1. Then try a fresh install of the latest version of SVCD2DVD.
    Dec 2005
    Thanks for the reply.
    I did as you suggested but that didn't work.
    But what I did do was remove all the codec packs I had installed and some other junk from my sytem and now it works.
    It seems it was the FFDcodecs was causing the crash. My previous attempt to roll back was unsuccessful, better just to unistall them completely. I also installed a new aspi17 driver. (not sure if that had any effect or not)
    I am now using K-Lite Codec Pack 2.48 Basic and everything seems to be running fine. (Fingers Crossed).
    Maybe a approved set of codecs available from the SVCD2DVD site would be a good idea. (But I guess there is so many that may not be possible)
    Again thanks for the help.
    best wishes
