Problem one - I tested a couple of small vobs ( trailers ) and some where successful with Xvid but some wanted to connect to the net to find suitable codecs that I presumed I already had - I must have them if some ofthe other trailers worked okay. Is it potluck with SimpleDivx? Did it just screw up the conversion for the Xvid avis that wouldn't play?
Problem two - subtitles. I just made a Divx avi - the subtitles only run for about 50% of the Divx movie. Why would that happen?
Problem 2 solved. The subtitle ripper ripped the subtitles and the timeline was slighty screwed - the times were correct for the first half and then the timeline jumped an hour or so which is why I had no titles showing after the first half. Used another subtitle ripper and all was okay.
SimpleDivX, and cropping/resizing
By snafubaby in forum DVD RippingReplies: 2Last Post: 21st Dec 2008, 16:39 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 02:28 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 15:23 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
SimpleDivX replacement
By alan79 in forum DVD RippingReplies: 3Last Post: 18th May 2007, 11:34
