Well i've searched and searched but cannot find any answers to my problem. I have been using Mpeg-vcr to cut commercials form my captured mpegs but the audio gets progressively worse after each cut. I have tried using other programs to cut with but have not found any that lets you cut inside the range of the mpeg like Mpeg-vcr. Most only let you trim begining and end. I am capturing to mpeg 720x480 DVD in Winfast PVR with a Winfast card. Is there any program that cuts as easy as Mpeg-vcr but works? If not should I capture to a different format (AVI) to make editing easier? I've tried using a lot of programs for editing but still get audio sync problems and i'm tired of it! Is there any "fool-proof" method of capture-edit-author to dvd?
Oh and one other thing. I have read the sticky on audio sync problems but no help.
Running XP Pro with AMD 3200XP, 1gb ram, Leadtek Winfast capture card, 2 drives, dedicated soley for video.
cuttermaran ?
Basically, mpeg bites for editing. It wasn't designed for editing, which is why most editors do it so poorly. Mpeg-VCR is one of the better ones, and enjoys a pretty good reputation around here for doing just what you are trying to do. Cuttermaran also has it's fans, so might be worth a try.Read my blog here.
I too use mpeg-vcr to cut commercials from my Hauppage PVR250 captures, and haven't had one single sync issue - so I'd rather think there's something with the captured mpegs that makes 'em unfit for cutting.
Only thing to do is try different apps IMO.
/Mats -
Thanks, I have tried Cutterman and video redo but couldn't quite figure them out as easy as Mpeg-vcr. I'll give them another shot. I'll also start saving as AVI if that will make it easier.
Working with mpg2 isn't as bad as all that, although as posted, it's never been designed for editing. OTOH, I think the folks at womble have gotten rite, so maybe the prob is in the software we've got to work with.
In theory there really shouldn't be any limitations because we're still dealing with a picture generated from data stored in a file.
"Is there any program that cuts as easy as Mpeg-vcr but works?"
Check out womble software. Project X works well if you can live with cuts to the nearest i frame, or perhaps capture all i frame.
"Is there any "fool-proof" method of capture-edit-author to dvd?"
If you can live with the re-encoding, capture max bitrate mpg2, then go the DGIndex route with VFAPI or Anysynth acting as proxies or to render avi as a mid-step. Then re-encode to mpg2, which in my humble opinion gives better quality then capturing to DVD specs.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
