I need a .mpa file to keep following the guide at http://forum.digital-digest.com/showthread.php?t=56599
DGIndex can demux an audio stream from MPEG source.
DGIndex can decode *.AC3 to a wav file.
DGIndex cannot find a *.MPA that isn't there. It doesn't encode at all. DGIndex is a Frameserver/Demuxer/Audio Decoder.
You'll have to either demux the *.AC3 and reencode to *.MPA with ffmpegGUI (or similar), or decode to *.WAV and encode that to *.MPA.
For the destination type.....
*.MP2 can be renamed to *.MPA.
*Of course, if you will be using DGPulldown, why not just leave the *.AC3 alone. AC3 seems to be the destination file type of this guide.
If 0ms DELAY is listed for the AC3 you will be doing alot of work for no benifit.
--edit--
The point of using DGPulldown is so you don't have to alter the length of the audio.
BTW, this guy is the author of both DGIndex AND DGPulldown;
Originally Posted by gastorgrab
I don't know anything about any of this... all I can do is follow the guide step-by-step. If a step doesn't work, I'm dead in the water until I can get an answer as to why.
DGIndex makes Video out of sync with Audio - please help!
By VideoFanatic in forum Video ConversionReplies: 10Last Post: 16th Oct 2011, 16:53 -
DGIndex creates .ac3 file double in length (timewise) of video
By karpodiem in forum Video ConversionReplies: 1Last Post: 20th Jul 2011, 15:51 -
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 06:52 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 12:39 -
Mpa to ac3 5.1
By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 18:43
