I have a Leadtek PVR2000 card I've been using successfully for a while with my old system (1.6 ghz AMD w Win Xp Pro). Just had to buy a Hp Pavilion when the old one finally died. This P4 system has Win Media Center 2005. My capture card isn't on the approved list of capture cards, but I threw it in, installed the drivers and I was able to successfully use the TV tuner. I can also still do AVI captures.
When I finally got around to doing a hardware Mpeg-2 capture (which I could do in the old system) I got a 'fail to use the codec - hardware mpeg2 codec' error message. I realize this may be because of the OS but if anyone has any ideas that could make it work , please suggest one.
I tried reinstalling the drivers.
FWIW The files in the driver install program are:
cpnotify.ax, prxypage.ax, msvcp70.dll, msvcp70d.dll, msvcr70.dll,
msvcr70d.dll, & cxtvrate.dll
I ran Gspot to see the list of video codes & it reports:
DMO WMVA WMVideo Advanced Decoder DMO Microsoft Corporation qasf.dll --> wmvadvd.dll
DMO MP4S Mpeg4s Decoder DMO Microsoft Corporation qasf.dll --> mp4sdmod.dll
DMO WMV Screen decoder DMO Microsoft Corporation qasf.dll --> wmsdmod.dll
DMO WMVideo Decoder DMO Microsoft Corporation qasf.dll --> wmvdmod.dll
DMO MP43 Mpeg43 Decoder DMO Microsoft Corporation qasf.dll --> mp43dmod.dll
DMO MPG4 Mpeg4 Decoder DMO Microsoft Corporation qasf.dll --> mpg4dmod.dll
DSH DV Video Encoder qdv.dll
DSH Indeo® video 5.10 Compression Filter Intel Corporation ir50_32.dll
DSH LEAD MCMP/MJPEG Codec LEAD Technologies, Inc. LCodcCMP.dll
DSH MJPEG Compressor quartz.dll
DSH MPEG1 MPEG Video Decoder quartz.dll
DSH MPEG2 InterVideo Video Decoder InterVideo Inc. IVIVIDEO.ax
DSH MSS1 Microsoft Screen Video Decompressor Microsoft Corporation msscds32.ax
DSH WMV1 Windows Media Video Decoder Microsoft Corporation wmvds32.ax
DSH WMV2 Windows Media Video Decoder Microsoft Corporation wmv8ds32.ax
DSH MP43 Microsoft MPEG-4 Video Decompressor Microsoft Corporation mpg4ds32.ax
DSH DVSD DV Video Decoder qdv.dll
DSH IV50 Indeo® video 5.10 Decompression Filter Intel Corporation ir50_32.dll
DSH IV41 Indeo® video 4.4 Decompression Filter Intel Corporation ir41_32.ax
DSH MJPG AVI Draw quartz.dll
DSH Video Port Manager quartz.dll
DSH MPEG1 MainConcept MPEG Video Decoder MainConcept AG mcdsmpeg.ax
DSH MJPG MJPEG Decompressor quartz.dll
DSH AVI Decompressor quartz.dll
DSH QTRpza QT Decompressor quartz.dll
VFW CVID Cinepak Codec by Radius Radius Inc. qcap.dll --> iccvid.dll
VFW HFYU Huffyuv v2.1.1 Disappearing Inc. qcap.dll --> huffyuv.dll
VFW I420 Intel 4:2:0 Video V2.50 Microsoft Corporation qcap.dll --> msh263.drv
VFW IV32 Intel Indeo(R) Video R3.2 qcap.dll --> ir32_32.dll
VFW IYUV Intel IYUV codec Microsoft Corporation qcap.dll --> iyuv_32.dll
VFW LEAD LEAD MCMP/MJPEG Codec (VFW) LEAD Technologies, Inc. qcap.dll --> LCODCCMP.DLL
VFW M261 Microsoft H.261 Video Codec Microsoft Corporation qcap.dll --> msh261.drv
VFW M263 Microsoft H.263 Video Codec Microsoft Corporation qcap.dll --> msh263.drv
VFW MRLE Microsoft RLE Microsoft Corporation qcap.dll --> msrle32.dll
VFW MSVC Microsoft Video 1 Microsoft Corporation qcap.dll --> msvidc32.dll
1st off may be a driver or compatibility prob, so might google on your capture hardware & OS etc... 2nd thought is you really don't need hardware compression anymore, so it might be easier and give a better result going to software compression to mpg2 during capture. I've got a modest machine and it uses something like 13% of cpu capturing to mpg2.
Separate from drivers, I've usually seen codec related files installed that you've not listed as being in your card's install program -- is there something or options maybe you haven't installed that came with your card?
Otherwise, it can get complicated - the way windows handles codecs is sort of dismal -- basically it will use what it feels like. Another prob. is different prog. basing their bundled codecs on the same licensed code (mainconcept is common), but altering it a bit so individual files are not compatible between versions. Installing older software can't be counted on to replace newer, incompatible, encoder related files.
In your situation, I think I'd 1st compare files that would be installed with your card, and then comparing them to versions already installed either with windows or other apps. In case of conflicting versions, have had limited success making sure all needed files are located in the program's file folder rather then windows\system or system32, &/or renaming files with the same name. Sometimes I've had success making sure files needed by the prog are registered using regdrop.exe
DXMan from AnalogX can tell you which files are registered to be used in windows, and can be a big help tracking this stuff down. It may be worth a try renameing files to disable your mainconcept, intervideo, & lead codecs.
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 02:56 -
avi to mpeg2 burning problem
By deadwreck09 in forum MacReplies: 4Last Post: 19th Nov 2009, 13:17 -
Problem with mpeg2 decoder.
By tehuser in forum Software PlayingReplies: 5Last Post: 24th Mar 2009, 18:59 -
mpeg2 playback problem
By mike20021969 in forum Capturing and VCRReplies: 8Last Post: 26th Aug 2008, 09:25 -
Problem with Virtualdub-MPEG2
By deepakOne in forum Video ConversionReplies: 2Last Post: 5th Oct 2007, 02:35
