I have an already authored dvd with two languages on it (english/chinese). Currently if I put the DVD in the player it will play chinese first, is there anyway I can edit the dvd so that it will play english first? Thanks.
Here's one very easy way:
http://forum.digital-digest.com/showpost.php?p=296707&postcount=1
However, I much prefer this way:
http://home.tiscali.be/debie.roland/pgcedit/third_party/blutach/How_to_use_PgcEdit_new_macro.htm
Although there's more of a learning curve, it's a much more elegant solution, and in the process you'll learn how to jump directly to the menu, bypassing any warning screens, logos, etc.If you need to set your audio and subtitle preferences after your breakpoint is reached, simply trace through to them and back to your breakpoint.
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
Change default audio in .VOB or .MPG files
By dsmith1984uk in forum AudioReplies: 1Last Post: 4th May 2010, 05:10 -
TMPGEnc AW 4: default audio stream for different tracks
By reini in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2009, 15:33 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 20:10 -
How can I change default audio track with DVD Flick?
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Feb 2008, 07:16
