So is your pc chock full? Mine almost is. 3 pci slots are all full (fax/modem, Radeon 9250 vid card, fusion 3 hdtv cap card) 2 harddrives (1 80gb, 1 160gb), 1 stock dvd/cdr drive, 1 4x single layer dvd burner, 1 soundblaster live external usb soundcard.
Basically I'm at max capicity. Though I could stick one more stick of ram in my extra ram slot![]()
Results 1 to 14 of 14
Nope and mine will never reach max capacity because I build my systems.Originally Posted by MichelangeloBelieving yourself to be secure only takes one cracker to dispel your belief.
So how many empty drive bays and component slots do you have then?Originally Posted by Dv8ted2Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
System 1 - One empty optical drive bay, One empty floppy drive bay - and several empty bays for hard drives - One empty slot for RamOriginally Posted by yoda313
System 2 - Three empty optical drive bays - one empty floppy drive bay and plenty of room for hard drives.Believing yourself to be secure only takes one cracker to dispel your belief. -
12 hard drives and 2 optical drives, sata card in 1 PCI slot, ATA card in another, and a Geforce 4 Ti4600 in my AGP slot.
Other system, 3 hard drives, 2 optical, and dual Geforce 6800GT series cards. -
WOW! That's fifteen power cables not including fans! OUCH!Originally Posted by DGenerateKane
As my main machine, I'm using an 11 bay case with three Hard drives and 1 DVD Burner. All PCI slots are available(3) and one PCI-E Card.
damn..all of a sudden I embarrased to tell you all what I have (or dont have)!
If at first you don't succeed; call it version 1.0 -
All my 5.25 drives bays are full, using all 4 bays. 3 hard drives, one PCI slot being used (audigy 2 platinum), thinking on getting a tv card yet.
Mine used to be really full. 3 dvd drives, 3 hard drives. and 3 pci cards plus agp card.
Soon gonna be only 2 drives -1 HD -2 pci cards,agp card -
all 4 of the big bays are full -- DVD-Rom, DVD burner, control panel for sound card, and the 4th has the control panel for my PSU and the floppy drive in it.
3 hard drives ( plenty of room for more!), a 40G, an 80G, and a 160G.
only using 2 PCI slots -- 1 for sound card and 1 for and PCI/IDE card giving me 2 more IDE slots
AGP slot is full (of course)
3 RAM slots, currently only using 2 of them -- matching 512M sticks
no need for most add-on cards as the MOBO has 2 LAN ports, a ton of USB 2.0 ports, and the sound card has firewire ports on it.
once the prices on 10,000RPM SATA hard drives drops down into the realm of reality, I'll be adding at least an 80G"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
This system has 3 hard disk. 2 120GB configured in Raid 1 (connected to the Promise card). Also there is a 160 GB connected to one of the internal IDE ports.
There are only 1 AGP and 3 PIC slots filled with: AGP video, Promise FastTrack 66 card (old IDE raid), Sound blaster audigy 1, Adaptec 2940AU SCI card. Internal 100 mbps NIC card in use.
2 Internal SATA ports are not used.
3 of the 4 drive slots a full: 1 DVD burner, 1 DVD-RAM burner and 1 Creative Live drive I, all connected to the internal IDE. Floppy bay is filled with an Imation Supper disk. 3 HD slots available. 3 internal fans in use. There are 4 memory slots but only two of them are used. Power supply lines have been exhausted. Externally I’ have some other stuff connected through serial port, SCSI, firewire and USB.
I will be installing a gigabit card soon so I will remove the internal SCI card and replace it with an external firewire-scsi converter. -
System one is a P4 2.4 pc has 3 dvd burners, 1 dvdrom, 2 hard drives, a floppy drive, pci controller card & pci adaptec firewire card.
System two is a P4 3.0 pc has 2 dvd burners, 1 dvdrom, 2 SATA hard drives, 1 ATA hard drive, floppy drive, silicon image chipset 680 controller card, pci network card, pci adaptec firewire card.
System three is a AMD socket 754 Sempron 2800 pc has 1 dvd burner, 1 dvdrom & 1 hard drive.
System four is a P4 2.26 pc has 1 dvd burner, 1 dvdrom, floppy drive & 2 hard drives. -
System one: Pentium 4 HT 3.2ghz, TV wonder card, Sounblaster Audigy Card, PCI Xpress ATI Card, Ultra ATA card (chucked the dialup modem) 2 free PCI slots. 2 Internal HD 1-250 1-160, 2 Optical Drives: 1 DVD Burner, 1 DVD Reader. 1 free 5.25 bay, 1 free floppy bay. Two free RAM slots with 1 gig installed.
System 2 (My powerhouse system): 1 - 3gb harddrive, 2 optical drives: 1 DVD Rom and the older CD burner you've seen a in a long time (burns at 2x), All PCI slots are filled save 1. Soundblaster Live card, Wireless NIC, NVIDIA RIVA TNT2 card, a Full 384MB of RAM, 450Mhz Pentium II.
System 3: 60GB harddrive, 1 DVD Rom Drive, 256MB ram, 500MHZ Pentium III, all installed in a small cardboard box (compared to mine, the guy that installed his PC in a cardboard box looks like a chump). Can you smelling the burning paper. (actually, I had no space for cooling fans so I cut a hole in the side of the box for ventilation. When I use the PC, I turn a fan on outside the box and blow it over the whole unit. Despite the cramped quarters of the box.) Next project: Put a PC inside a stereo component case so I can use it for media purposes and it won't look like a pc.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
External Hard Drives...How Full Is Too Full?
By bbanderic in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2010, 17:25
