hi i tred to convert scvds to dvd and avi to dvd but the video and the audio arent perfect its like 3-5 secs delay or something and i relly need to format my computer but before iwana rip these movies into dvds please help me i used dvd santa and dvd lab with both i saw the delay.. and i also tried The Flim Machine and it was perfect for avi to dvd.. but it seems to close after few seconds like i just click 'make dvd' and after few secs it just automatically closes.. please help thank you bye
if you noe other free ways to convert avi to dvd and svcd to dvd please tell me here
Results 1 to 16 of 16
Try to use complete sentences. Try to not make so many typos and don't use kiddie net slang. Why? Because I cannot even remotely understand what you're asking.
You can correct the delay in DVD Lab Pro
Read my blog here.
hey i did change the setting in project settings.. but its still not working.. i still get that message someone please help
mpeg file do you know any other software to convert svcds into dvd? because i want to format my computer but i cant because i have about 50 gb moives so i really need it...
ok when i laod it it asks if i want to demultiplex that option.. and then this window pops up saying Errors and Warning and says => cause cant read the file is in use => if the file is on dvd, try to unlock the drive => by playing the dvd with some software dvd player and then => Cause: Cant access the file => if such file exist check if it is not in use. and i even restarted my comp and then tried it.. but it still showed that..
Have you tried copying the mpeg files to your hard drive and making sure they aren't set to read only ?
This is a problem with the way you have the files, not with DVD Lab ProRead my blog here.
its already in my hard drive and its in mpeg format.. i even tried a different movie with same format and it still showed the same error
Did you rip the files using ISOBuster, or just copy them off the CD ? If you just copied the file, try using ISOBuster to extract the mpeg back to the correct format, then follow this tutorial http://www.mediachance.com/dvdlab/tutorial/svcd.html
Read my blog here.
its in mpeg format and it worked before.. but now its not working.. i didnt use iso buster..
My MKV file already has AAC audio so the conversion tools arent working
By animlchin in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 18:58 -
Lap top audio doe not work
By romanstopme in forum ComputerReplies: 2Last Post: 8th Nov 2008, 14:43 -
dvd +r made on lighton 5001 can't be read on desktop or lap top
By skydiverbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Jan 2008, 15:02 -
Can't play dvd on my lap top!
By BSarte in forum Software PlayingReplies: 2Last Post: 16th Sep 2007, 08:43 -
VOB, AVI TO RM problem with audio and vedio sync
By soft in forum DVD RippingReplies: 1Last Post: 8th Aug 2007, 01:16
