I have read many posts of people not being able to remove some files from their desktop, here is the solution.
There is a FREEWARE APPLICATION called Unlocker v1.7.5
Unlocker is an Windows Explorer extension allowing you with a simple right-click on a file or folder to get rid of error message such as error deleting file or folder, cannot delete folder: it's being used by another person or program.
Helps delete locked files with error messages like:
- Cannot delete file: Access is denied
- There has been a sharing violation.
- The source or destination file may be in use.
- The file is in use by another program or user.
- Make sure the disk is not full or write-protected and that the file is not currently in use.
Here is the link.
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
ctrl-alt-delete to end process or a boot into safe mode will due the same
Removing audio files from BD backup
By dvbuljan in forum Blu-ray RippingReplies: 8Last Post: 18th Nov 2010, 16:43 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
Removing VirtualDub from Computer
By Sidus1 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 17:04 -
Need help on reinstalling ffmpegX after removing the program on my computer
By DDieggo1000 in forum ffmpegX general discussionReplies: 1Last Post: 28th May 2009, 13:49 -
removing letterboxing on MPEG2 files
By hellsaviour in forum MacReplies: 3Last Post: 13th May 2007, 14:17
