I'm trying to endode an avi to dvd.
the dvd doesn't have sound if I encode with ffmpeg only if I use mpeg2enc and decode with mplayer
when I play the video from the button at the top next to the source and target fields, the audio is in sync
the summary for the source file is
video: mpeg4, yuv420p, 576x304
audio: mp3, 48000 Hz, stereo, 128 kb/s
the source is also 23.976 fps and I selected 29.97 for output
does anyone have recommended settings that would encode properly?
The 3:2 pulldown will let your DVD player ouput a 29.97 signal to your tv, IIRC. The same technique is used on DVDs from the major studios.Originally Posted by trevytrev
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
