Results 1 to 30 of 33
    Dec 2005
    I get this message after encoding "Encoding started on Mon Dec 26 23:30:16 EST 2005
    Input #0, mov,mp4,m4a,3gp, from
    '/Users/StephenLevinson/Desktop/bobsquarepants-tlr4_321.mov':
    Duration: 00:02:27.3, start: 0.000000, bitrate: 1407
    kb/s
    Stream #0.0: Audio: pcm_s16be, 22050 Hz, mono, 352
    kb/s
    Stream #0.1: Video: mpeg4
    Output #0, mp4, to
    '/Users/StephenLevinson/Desktop/M4V08428.MP4':
    Stream #0.0: Video: xvid, 320x240, 29.97 fps, q=3-9,
    300 kb/s
    Stream #0.1: Audio: aac, 24000 Hz, stereo, 32 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    video:12kB audio:1151kB global headers:0kB muxing
    overhead 43.455759%
    bench: utime=17.736s
    1 video MPEG-4 Unknown Profile(0), 147.347 secs, 98
    kbps, 320x240 @ 29.97 fps
    2 audio MPEG-4 AAC LC, 147.157 secs, 98 kbps, 24000 Hz
    Encoding completed on Mon Dec 26 23:30:38 EST 2005"
    When i play that cclip its just colors changing. I put the file on the psp, and its just colors that are changing.. its weird. I tried ith another video and i got the same exact result. Does anyone kno how to help me?
    Steve
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I solved that by going H.264 > 3ivX > H.264. I needed to encode twice anyway, to change the aspect ratio by adding black bars in QuickTime Pro.
    Dec 2005
    Forgot to mention, this is for the ffmpegx program
    Dec 2005
    Where is this h.264/3ivX.h.264.? I dont see it in quicktime
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Mea culpa. PSP preset in ffmpegX is XviD, not H.264.
    Source trailer is H.264 video in a MOV container.
    Then encode to 3ivX (MOV) high bitrate, constant quality Qmin=Qmax=2, in QuickTime Pro. You may substitute 3ivX with any other high quality progressive codec (not being H.264). It's just an intermediate step in which you want to preserve the video as much as possible.
    Then encode that to PSP (XviD video) with ffmpegX.
    Thus, from H.264 to 3ivX, then 3ivX to XviD. Or "H.264 > 3ivX > XviD" for short.
    Dec 2005
    Ok, i did everything but the qmin-qmax2 which i dont understand. I just left that part out and still got same results.. its pro cause of that. Sorry, im not so great with these types of things
    Steve
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I'm using the 3ivX codec for this, so you'll need to have that installed. Open the trailer in QuickTime Player. Choose Export from the File menu. Enter a new Save As filename. Export: Movie to QuickTime movie. Choose Options. Change Video Size to 320x240. This will improve encoding time, as your end result will be 320x240 anyway. Change Video Settings. (In short: set everything to maximum Compression type: 3ivx D4 4.5.1. Framerate: current fps. Compressor: Quality: Best. Choose Options in the Compressor part of the window. In Basic Options, set Encode Mode to Single Pass, Constant Quality. Set the slider almost to the right, where the quantizer parameter reads QP 2 = 100%. In Advanced Options, check all checkboxes. [OK] [OK] [OK] [Save] Wait. Test watch.
    Dec 2005
    Thankyou, i did everything correctly, but now after using ffmpegx it still is changing different colors.. hmm ..
    Steve
    Should i just put the exported from quicktimeon the psp?
    Dec 2005
    Sorry, this is the "i" i get
    "Encoding started on Wed Dec 28 13:25:54 EST 2005
    Input #0, mov,mp4,m4a,3gp, from '/Users/StephenLevinson/Desktop/blahblah.mov':
    Duration: 00:02:27.3, start: 0.000000, bitrate: 807 kb/s
    Stream #0.0: Audio: pcm_s16be, 8000 Hz, mono, 128 kb/s
    Output #0, mp4, to '/Users/StephenLevinson/Desktop/M4V09693.MP4':
    Stream #0.0: Video: xvid, 320x240, 29.97 fps, q=3-9, 300 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    video:13kB audio:1007kB global headers:0kB muxing overhead 70.768334%
    bench: utime=19.176s
    1 video MPEG-4 Unknown Profile(0), 147.347 secs, 98 kbps, 320x240 @ 29.97 fps
    Encoding completed on Wed Dec 28 13:26:23 EST 2005
  10. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Unless you edited this
    the line seems incomplete, as in my example I get
    Stream #0.1: Video: mpeg4, 320x240, 23.98 fps
    that is, size and framerate should be included in that line, which could be a symptom of decoding failure.
    Does the input file look good in QuickTime?
    Does the input file look good in ffmpegX (Play-button on top)?
    Dec 2005
    Yes it looks good in qiucktime, and when i hit play nothing happens
  12. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Do you have the 2005-12-01 version of mplayer installed with ffmpegX?
    Dec 2005
    I do not have mplayer installed...im not sure how to download it.. when i click on on install it asks to locate it on my computer but its not yet there
    Steve
  14. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Ah, that would be the reason for this problem then.
    When you start up ffmpegX, you may get the "self-installer" window, or else choose "Install binaries" from the ffmpegX menu. Three checkboxes with URLs on the right. Copy-paste to your browser. Download those. Note that checkbox 2 and 3 have the same URL, and point to a zip file with both binaries inside. Unzip the file, then use the Locate button in ffmpegX to locate mencoder and mplayer. Press Install.
    Dec 2005
    The link on the first one just goes to an html page no download .. it goes "http://mjpeg.sourceforge.net/MacOS/"
  16. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    1. You won't need mpeg2enc for this conversion. So skipping it for now is okay.
    2. Near the bottom of that page, is a link to mpeg2enc. Since it links to a file without suffix, some browsers may wrongfully display the binary as text in a browser window when clicked. To avoid this, Cmd-click (hold down the Apple/Clover button while clicking) to force a browser to download that link to file.
    Dec 2005
    Omg! i still get the same thing happening! This is what my file now says "Encoding started on Wed Dec 28 21:27:21 EST 2005
    Output #0, mp4, to '/Users/StephenLevinson/Desktop/M4V05507.MP4':
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    bench: utime=19.164s
    Encoding completed on Wed Dec 28 21:27:45 EST 2005
    Steve
  18. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Does the Play button in ffmpegX work now? If not, try to log out first and start over. Sort of a fresh start kinda thing.
    Dec 2005
    Play and Preview both work now. When i hit play i see it but no sound, when i hit preview, just colors and sound. I get this message "Encoding started on Wed Dec 28 21:45:05 EST 2005
    Output #0, mp4, to '/Users/StephenLevinson/Desktop/M4V08518.MP4':
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    bench: utime=18.981s
    Encoding completed on Wed Dec 28 21:45:27 EST 2005"
    Steve
  20. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I guess that's normal, I get that here too, as I try to duplicate your file. Maybe that's part of the odd PSP movie format.
    Try playback of M4V08518.MP4 in QuickTime Player. The aspect ratio will be off (16:9 squeezed into 4:3), but video and sound should be okay. Then try playback on a PSP.
    Dec 2005
    When i open it in quicktime its the colors just like when i have it on the psp
  22. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Still unsolved, hmm. Your Preview colors don't look like this then?
    The missing video info on the mpeg4 in the log must be key then. Maybe major (the author) knows more. Because my log always shows size and framerate.
    Edit: link fixed
  23. Member
    Dec 2005
    My quicktime looks like this but many different colors at diff times and it changes with the beat of the audio www.stephenstudios.com/1.png
  24. Member
    Dec 2005
  25. Member
    Dec 2005
    Should my ffmpegx look like this? www.stephenstudios.com/2.png
    and should my video look like this? www.stephenstudios.com/3.png
    Steve[/url]
  26. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I get a different Video 'display' in the Source Format section: no yuv420p on my side, but a framerate mentioned there. Other than that, the screenshots seem fine.
  27. Member
    Dec 2005
    Do u kno what i can do to fix my problem? I tried deleting the program then re-installing it but it didnt do anything.
  28. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    There's a chance something's odd with your input file and ffmpegX is fine. If you will, try the file I succesfully transcoded.
  29. Member
    Dec 2005
    It worked and its on my psp..how did u get it to do that?
  30. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Just took the online trailer, used QuickTime Pro to export to a more compatible format, so that ffmpegX would handle it.
