I've used CCE and gone through some recommended settings for converting AVI. The problem I've seen regularily is that after setting everything up and converting to mpeg, the file length is shown as shorter than it started.
As an example, an AVI i converted was 1:48 long and the converted mpeg showed 1:33. The AVI demuxed audio showed the correct length when opened in DVDlab, the video showed the shorter length.
I'm not sure if there'll be a problem when they are muxed in DVDLab.
This happens with almost every CCE encoded AVI to Mpeg (NTSC).
Has anyone else seen this and do you know what causes it/ how to correct?
Example - demuxed an ac3 stream with VD - 2:24.56
Opened AVI up in CCE - 1:55.56
I'm going to run and use DVDlab to author. Not sure why the discrepancy.
Note: Audio and video were out of synhch.
Results 1 to 1 of 1
corrupt .mts file (incorrect length)
By sandergoorden in forum Video ConversionReplies: 55Last Post: 30th Apr 2015, 08:56 -
DVD Subrip shows incorrect timecodes !
By Chainsaw_1 in forum SubtitleReplies: 2Last Post: 31st Mar 2010, 18:28 -
Video file time length is incorrect after converting to M2TS
By Alterego in forum Video ConversionReplies: 0Last Post: 18th Oct 2008, 10:54 -
AVI->MPEG2 (CCE Basic) encoding results in incorrect video length in pla
By binister in forum Video ConversionReplies: 8Last Post: 26th Feb 2008, 17:29 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 11:14
