Hello everybody
I want to burn my movie to a DVD but I don't know what software to use.Can somebody give me some ideas please
Thank you in advance
are you going to backup a dvd to dvd?
https://www.videohelp.com/tools?s=19#19
https://www.videohelp.com/dvdbackup#6;65
if your movie is in some other format
https://www.videohelp.com/convert#4;62 -
can you please tell me which is the best converter from AVI/DIVX to DVD?
For the best you need a selection of tools - a good encoder, a bitrate calculator, perhaps avisynth or virtualdub, and some authoring software, and the time to learn how to use it correctly.
If you just want a reasonable job done fast, DivxtoDVDRead my blog here.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
