    Apr 2003
    When using virtual dub to convert an NTSC avi to pal for some reason it has started creating a file that is over 20gb when the original size is only 750kb
    What i am doin is opening the avi in Virtual dub saving the audio as WAV converting the WAV to Pal using besweet GUI then using Virtual dub again to change the frame rate to 25fps and using the new WAV file that was converted as the audio and then selecting save as AVI, i have used this method many times and have not had this problem before,
    Does anybody know what could be going wrong?
    select video->direct stream copy or else will the video be converted to uncompressed video=HUGE.
    Apr 2003
    as simple as that so sorry for wasting your time!
