i used my ati card and copied a vhs tape. its in mpeg format. the problem is that its too big to fit on a dvd. how do i shrink it down to fit on a dvd ?
thanks
greg
You should have encoded it to the correct bitrate to begin with, then it would fit.
Find the running time, and then use on of the bitrate calculators in the tools section ( like this one -> https://www.videohelp.com/calc.htm) to determine the correct bitrate. Now reencode using thesenumbers and it should fit.
What format is the audio in ?Read my blog here.
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 05:12 -
shrinking a dvd file to email it
By Haopengyou in forum Newbie / General discussionsReplies: 9Last Post: 13th Jul 2010, 10:41 -
Converting & Shrinking to 1 DVD
By poppy56 in forum Newbie / General discussionsReplies: 4Last Post: 4th Oct 2008, 16:54 -
shrinking a dvd so it can fit on a regular 80mb dvd instead of dl
By funkymonk in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2008, 17:22 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43
