I followed this guide, http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit, and when I played the dvd, the sub title is super bolded in color green and is unreadable. Any idea why this is the problem and how do I resolve this problem.
The easiest thing to try I think would be to open the original & new vts ifo files in IfoEdit. For the original, click on VTS_PGCITI, then on VTS_PGC_1, select copy colors from this PGC (under Subtitle Color menu), go to PGC_1 etc the same way on your new ifo, and this time select Paste colors into this PGC. Otherwise there are a few guides covering how to edit/set sub colors.
Another way to approach this I think might be to use an authoring prog. to have one video play immediately after the other, then use VobBlanker as (or if) needed to replace created vobs with originals containing subs - not all authoring prog. will accept non-text subs. Read the guides at videohelp.com however - you'll have to turn the subs on in the new ifo's, and set color as above.
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 07:45 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16
