I just started using Premiere and found something that I can't figure. When capturing using Premiere it will stop the capture process all on it's own. And at different points on a VHS tape. I am caputuring using Canopus ADVC 55 and a Panasonic AG-1960. Since I am a real newbie with Premiere is there a setting I am missing? I have other capture programs but would like to get Premiere to work for me. It sees the preview just fine and capture starts fine too. Somewhere along the way it just stops the capture process. Once it was at 8 minutes, in another it made 15. No error message it seems like it is acting as though I told it to stop capturing, which I didn't. Wierd. And, no it isn't a demo. And this isn't a Macrovision or copyright issue.
The ADVC-55 is hardware converting VHS NTSC to DV format. Your computer should be fast enough.
What is your project format? I'll assume DV 720x480 29.97fps.
How do you have your scratch disks set? Make sure they are separate from the OS drive. You will need adequate free disk space.
Fat32 will divide files at 4GB (~18 min) but Premiere usually handles that with multiple files.
No other ideas for now.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
There may be a setting which tells the software to auto abort when there is a "dropped frame" event. You may want to check that! Or I should say, uncheck that!
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 14:59
