Results 1 to 11 of 11
  1. What is another all around dvd burning program besides Nero?
    I hate Nero, it's only goog for basic burning.
    I need something that works.
    Thanks.
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Nero is fine for doing a lot of things, but if you're looking to burn DVD-Video you should be using ImgTools Classic & DVDDecrypter.
    http://coujo.crion.de/Classic_0.91.6.zip
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. Basically, I'm trying to burn multiple "movies" to 1 dvd.
    Each is about 1.3 gig.
    Any help?
  4. Banned
    Feb 2005
    USA
    TMPGEnc DVD Author will do the trick.
  5. Thanks guys. I'll give them a try.
  6. These are VOB files. TMPGEnc doesn't seem to work on this.
  7. TMPG DVD Author is a program for DVD construction and can import multiple parts of DVD's to create a complation.
    http://www.pegasys-inc.com/en/product/tda.html
    TMPGenc is an encoding program and does not create DVD files.
  8. You can use DVDShrink in re-author mode to select video files from multiple folders on your hard disk to be included in your final dvd. If you let DVDShrink output to a file folder, then you can burn with whatever program you prefer. I use Roxio's EMC7.1 to burn media and find it to be 100% reliable on my system.
  9. Thanks again everybody.
    Sorry for the screw up.
  10. "Thanks again everybody.
    Sorry for the screw up. "
    Not a problem.
    The DVDshrink way I'd forgotten about. I use TMPG DVD author for just this type of job.
    DVDshrink should work just as well.
