  1. I am looking for a DVI switch box to go between the cable box and computer. So I am just looking for video, no KVM. Does this exist. I have seen one for HDMI at monoprice, but that is the closest I have seen.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    See
    http://www.ramelectronics.net/html/DVI_monitor_cables.html
    Cable box to computer? What kind of DVI computer input do you have? New to me.
    http://www.kiva.org/about
  3. Originally Posted by edDV
    See
    Sorry, should have explained a little more. I am looking to put 2 sources, computer and cable box, into my projector.
    So I want to use DVI out of the comptuer obviously over VGA and then I want DVI out of the cable box over component for quality reasons. So I am just looking for a simple switch box for DVI, manual and everything I just don't feel like paying $200 for something like this.
  4. Banned
    Sep 2005
    USA
    $200 is relatively inexpensive for a DVI switcher.
    A quick google shows them between $450 and $550.
  5. Member edDV's Avatar
    Mar 2004
    You don't need live switching. There may be a simple wired switch but it may require you to reboot the computer. Swapping cable on a patch panel may be the cheapest way to go.
    See this article for the issues.
    http://www.tomshardware.com/2005/07/15/kvm_switches_that_do_dvi_from_aten/
