I know this subject has been beat to death, but I have a new question - (I think.)
I have heard several different numbers, but for the sake of argument, I am finding that about 90% of home DVD players will play a DVD+R and about 95% will play a DVD-R. (numbers from internet articles, not my own testing)
The question is: Will 100% of home DVD players that can play a DVD+R be able play a DVD-R? Basically, if a DVD player will play a +R, will it play a -R everytime? I know that if a player plays a -R, it won't necesarily play a +R. But, vice versa?
Results 1 to 9 of 9
No. Usually, yes. Always, no.
Some equipment only understands DVD-ROM booktype. These are few and far between (>1%), but they exist. You must bitset the DVD+R to DVD-ROM for those.
Most equipment that rejects DVD+R barfs because of the physical aspect of the media. You can set to DVD+R or DVD-ROM and it won't matter, the unit hates the disc. These usually still play DVD-R just fine.
Then a great many play both.Want my help? Ask here! (not via PM!)
Thanks for the reply. I am starting a side business - video-ing and authoring DVD's. I guess there is no way to prevent selling a few where they won't play on the customer's DVD player.
From what I have gathered, DVD-R will be the best bet. -
Nope, no way to prevent it.
Only way to prevent it is to send it to a replicator and have them stamp out a couple hundred real DVD-ROMs. But that takes $$$.
Tip: Make sure you get a burner that does +R/RW as well as -R/RW. That way, if your clients can't use a particular type, the opposing type may work better. Another good thing to do (especially for the really clueless clients that don't know what they have, or how to troubleshoot) is make a set of "demo" discs in ALL the various book types, and have them try each one and see which one works with their player(s).
Remember, they'll have much better possibility of successfully reading the disc if it's VERY HIGH QUALITY media.
Scott -
My friend's Panasonic DVD Player wouldn't play my DVD+R backups. It would just sit there and spin. Then I reburnt them and changed the bitsetting to DVD-ROM. Now the DVD's play fine.
I do the same thing for people locally. The one way I have found to avoid making an incompatible disc for someone is to lend them a sample of both +/- R productions. That way they can test their own mahines. I know it sounds simple but it does some both money and headaches in the end. I have even come across so older mahines that won't play either.
cheers!All's well that burns well. -
My SONY dvd player is the first genaration one, I had it since 1997. It plays the DVD-R fine, if I burn it with TMPEG DVD author program but doesn't play if it is a DVD shrink DVD copy.
Ranjith -
Yep, same here!! my standalone recoder will not play or read a dvd+r, but when the booktype is changed to dvd-rom, no problem.Originally Posted by GabeB
Here is my experiance,
I have seen dvd players that would play both + & - dvdr,
Players that would only play -R and not +R, would play +R changed to ROM,
Players that would not play either + or - would not play +R changed to ROM,
Just in the last few months i have seen 2 players that would not play either + or - R's & would play +R's changed to DVD-ROM. and they were mobile or vehicle dvd players.
But overall, i have had a few problems with both dvd+r & -r's having problems, and since changing all of my dvd+r's "DVD-ROM" for the last couple of years i have had ZERO issues with10's of 1000's of disc's.
But the lack of problems may have to do with newer dvd players being more acceptable of dvdr's altogether.
But from my experiance over the last few years, i will always use +R because i can change the booktype so the disc's can be read as DVD-ROM and have yet to have an issue with them.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
