Not to me. Brazil adopts metric system.Originally Posted by jagabo
kilometers, meters, milimeters, gram, kilogram, liters, etc...
In fact, once you are used to a system, it's easy. But why do they complicate when they could simplify?
To me, k means kilo that means 1000.
If they wanted round, why didn't they create a new multiple?
I am a programmer too and I think computers should adapt themselves (by software) to men (and women) not the contrary.
Results 31 to 40 of 40
Originally Posted by AngusMacGyver
OK. I'll play!
Originally Posted by DereX888
Yeah, I know that the Navy uses/has used VLF for communicating with submarines, but normal people can't drag around super-long-wavelength antennas behind their cars or boats or airplanes. But I don't think that even submarines using VLF can use less than one Hertz. The quarter wavelength for one Hertz is 75 million meters or 246 million feet. You'd need a pretty long antenna for that, let alone a signal carrier with a wavelength a thousand times longer.
So using "milli" for Hertz is silly, as is using "milli" for bits or bytes. -
That's why in Brazil one hour is 100 minutes.... etc.etc.etc. -
Yes, but 64 minutes would be better, woudn't it?
One day would have 32 hours and a month 32 days. One year would have 256 days (maybe 512)... -
And binary $ or Euros would be 2, 4, 8, 16, 32 ...
http://www.kiva.org/about -
Originally Posted by ebenton
well, i'll go along:
millibit would hve to be an uncomputed 1 or 0 which is part of a bit
ACtually its possible - if we use some CPU with processing speed of say less than 1Hz, how long would it take to compute a 1 byte in one cycle? It would be possible that it computed a millibyte per second if it was slow enough
millihertz - I dont know, maybe a frequency thats stretched in time-space (kinda other dimension :P)? Your guess is as good as mine
But I would not dismiss neither as utter stupidity; probably 100 years ago or so people could not imagine a millisecond either, and nowaday (in regard to computers) a millisecond is an eternity actually -
That Wikipedia articles are wrong. I suggest someone edit it, or perhaps maybe I will.
1024 = 1KB
1 kilobit = 1000 bits -
@ ttn:
You are right, but you are also wrong. Indeed, you are more wrong than right because you are missing out entirely the historical context.
Yes, logically, a kilobyte should be 1000 bytes as per the SI system. However, a "kilobyte" (and the casing of the "k" is entirely irrelevant) has always referred to 2^10 bytes (i.e., 1024 bytes). A "megabyte" is 2^20 bytes and a gigabyte is 2^30 bytes (and so on). It is a misnomer yes, but an accepted and defined one. The defining/renaming by SI of the computing units (kibi, mebi, gibi) is again, logical, but also completely lacks legitimacy as they are not accepted by the computing world.
The usage of "1000 bytes" as a "kilobyte" was frankly a cynical marketing move by media sellers to "inflate" the nominal capacity. That, is the only reason why the confusion exists.
Regards,
Michael TamMichael Tam
w: Morsels of Evidence
1024 576 resolution not full screen in mpc
By mrwonker in forum Software PlayingReplies: 4Last Post: 18th Jul 2011, 15:40 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 12:02 -
Tbc-1000
By FreddieP in forum RestorationReplies: 7Last Post: 17th Jul 2010, 16:04 -
Problem with 1024, 1280 width
By kailmursili in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 06:22 -
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 21:59
