Hello,
I have a few .avi files that would like to author to DVD with iDVD.
Is it possible to simply convert the container from .avi to .mov, without changing the encoding of the embedded movie?
And how can you find out what the embedded encoding type is, to figure out if that is even compatible with QT/iDVD?
Thanks,
Avram
If you did, the contents of the avi would still have to be something QT could handle. For example, if the audio is mp3, QT won't play it (just like WMP won't handle vbr).
GSpot is freeware for reading the codecs/structure. If you don't have Virtual PC on your Mac, borrow a real pc and scan the files there.
False. QT can play MP3 fine in .mov files.Originally Posted by dnix71
Your first step is to have Quicktime play the original AVI files, best case scenario you just need the DivX codec installed. It's possible that the video or audio is in a format that there is no QT codec for, but try to just install DivX first.
When you have it working in Quicktime, you can use QT Pro or QTAmateur to save as a .mov.
DIVX Doctor II will convert your DIVX AVIs to Quicktime movies for you. It will "repackage" your video without transcoding. The audio will either be repackaged or converted to MP3 (whatever it takes to get to MP3). Works great and its free! Find it at versiontracker.com.
- macr0t0r
When did email start feeling like work?
How do I convert MOV dv files to AVI?
By SixStringSW in forum MacReplies: 10Last Post: 17th Mar 2011, 01:21 -
Convert .MOV to .AVI
By hcs in forum Video ConversionReplies: 4Last Post: 25th Sep 2010, 17:44 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
How would I convert MOV to AVI?
By Hittz in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 01:39 -
DV AVI to DV MOV - without re-encoding?
By arminio in forum Video ConversionReplies: 2Last Post: 4th Mar 2008, 05:42
