I have started a side business video-ing events and burning DVD's. For a general good practice, I want to back up all raw data (from camera - un-edited) to DVD for future use if needed. It seems that I can't back up a file larger than 2 gb. Any way around that?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
Theres no reason you shouldnt be able to backup a file larger than 2gb.
As a side note if this is your side business and your just backing up raw footage I would suggest using External HD for backup purpose. you will be able to store a lot on an external HD and can place it in a fireproof safe or store a duplicated external HD off site in case of disaster.
Backing up data from the computer hard disk to DVDs/CDs
By shashgo in forum Newbie / General discussionsReplies: 11Last Post: 27th Mar 2012, 10:17 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
Is Backing up DATA in Blu Ray Recordable Discs Reliable?
By faramith in forum ComputerReplies: 9Last Post: 8th Oct 2009, 09:46
