When i create SVCD i do so using a resolution of 480 x 576 knowing that the telecine ratio of display is 4 : 3. By that i guess you mean the final viewed frame display aspect. Often when i have to use a template for saving an edited version of a capture i am asked what pixel aspect ratio. What should i choose - 4 : 3 or 1 : 0,933 (ratipo of 480 and 576) or some other ? Do explain why if the answer is simple or else i'll go blind
Results 1 to 1 of 1
Pixel Aspect Ratio in virtualdub
By wabsnazm in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2011, 15:57 -
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 12:47 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 13:53 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 17:42 -
one more question about avi file's pixel aspect ratio
By compusic in forum Software PlayingReplies: 2Last Post: 25th Jul 2007, 02:43
