I have a simple task to perform .
I have few small mp4 clips that I need to join / edit and then write them to a DVD (mpeg ??).This need to be viewable on all DVD players .
what is the best software/tool/procedure required to achieve this .
Thanks lots
PM
yamb can join/cut mp4.
or convert each mp4 to clip to dvd mpg and join when you author with for example tmpgenc dvd author.
convert the mp4 to dvd mpg with for example The FilmMachine, winavi or use the avisynth method, https://forum.videohelp.com/viewtopic.php?t=284288&start=0&postdays=0&postorder=asc&highlight=
, and open the mp4 avs in any encoder/converter. -
Hi Baldrick,
Thanks for the assistance and pointing in the right direction.
I shall give it a go .
Cheers
PM
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 3Last Post: 20th Sep 2014, 15:06 -
Edit MP4 Files
By Tylerr in forum EditingReplies: 10Last Post: 4th Feb 2011, 16:23 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 15:46 -
How to edit MP4 with AVC video and AAC audio?
By nonexistent_entity in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2009, 07:58 -
How can I edit subtitles in a ,mp4 video?
By Belfry in forum SubtitleReplies: 3Last Post: 19th Oct 2007, 20:17
