Hi!
I have a problem converting rmvb files to dvd using dvd santa.Video ok accept sound all mix-up(eng. and french together).Is there anything i can do to fix this?THANKS in advance
Sounds like the audio had english on one channel and french in the other. Unless you can demux the audio from the rmvb and copy one channel over the other, there might not be much you can do.
When you play it back normally, how does it sound ?Read my blog here.
Hi!
When i play it back on comp. ok(using realplayer).The only problem when converting to dvd.Thanks
Stereo Mix - is there no sound quality loss ?
By Bansaw in forum AudioReplies: 2Last Post: 30th Apr 2011, 11:22 -
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 03:45 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 17:12 -
Error message with DVD Santa
By poppy56 in forum Newbie / General discussionsReplies: 8Last Post: 1st Feb 2008, 17:00 -
dvd santa and vista
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 13th Oct 2007, 14:31
