Hi,
I've been using the following help file for converting xvid movies to mpg and then burning them as a VCD or SVCD using MainConcept. Setting the split isn't a problem. (when there's only one file) It usually takes two or three CD's depending on how big the movie is.
https://www.videohelp.com/sefy/?id=divx2vcd.html
My troubles start when the xvid movie is already split into part one and two. Then when converting the first file with MainConcept I end up having to use to many CD's by the time I've converted both parts. Is there a good program that can be used to join the two xvid files before starting the audio rip and conversion?
Also, when using the above help file for AC3 audio it says to use the program HeadAC3he which I've never been able to get to work. I've installed it and all of the .dll's for it but it still wont load the source file. I always get an error that says it can't find the data chunk. Can someone point me in the right direction with AC3 audio decoding.
Any help would be greatly appreciated.
kwik
Originally Posted by kwik
You could also try using AVISynth to make a "fake" single file.
Originally Posted by kwik -
These are avi files? If so then I agree with VirtualDubMod for joining or AVIMuxGUI.
How did you extract the AC3? -
Originally Posted by celtic_druid
Originally Posted by celtic_druid -
Thanks for the relies. Yes, the Xvid is in AVI format. I'll try all of them and hopefully one will work out great.
kwik
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 10:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 16:41 -
LaCie LaCinema not playing all files correctly - Audio is off
By jhall_830 in forum Newbie / General discussionsReplies: 17Last Post: 14th Feb 2010, 06:35 -
How to join vob files -CORRECTLY!
By mcfcguvnors in forum EditingReplies: 18Last Post: 17th Jul 2009, 08:38 -
split a multi-angle dvd9 to two dvd5's questions
By spiritgumm in forum DVD RippingReplies: 5Last Post: 3rd Oct 2007, 18:25
