I;m trying to use LSX-MPEG Encoder to encode .avi2vcd. I know I need to uncompress the audio into PCM format. But, then I get This message:
Warning: Input video stream has a high level of compression. For best results, use uncompressed files or files with a low level of video compression.
So, How do I uncompress the video?
Thanks for any help.
You don't need to uncompress the video--LSX will do that for you.
Rather, it's warning you that the video has already undergone a "high level of compression" that might reduce its quality. By saying "use uncompressed files or files with a low level of video compression" they're recommending that you try not to compress the video in the first place.
problem encoding error decompressing video frame 0 :
By goingape in forum Newbie / General discussionsReplies: 7Last Post: 27th May 2007, 13:14
