Everytime I try to add my .avi file into TMPGEnc to convert to mpg, I get this error:
"File "file.avi" cannot open, or unsupported"
I looked in the common problems thread... I tried changing the priority of the VFAPI plug-in, and that didn't work.
I also made sure I have the required codecs.
I've converted 100s of times before, and have never encountered this problem. I can't figure out what else to try!![]()
So any help would be much appreciated!!
EDIT: I tried using TMPGEnc XPress, and it said "could not open the video part of file.avi, only the audio part can be opened" if that helps at all. The video plays perfectly fine in like windows media player or something though. =\
Yes, you're probably missing the video codec used, or have an old version installed.
/Mats -
Hi, I have much the same issue as the above...
I keep getting a response from Tmpgenc Xpress (3.0.4.24) on (only some) avi's stating that "Video part can not be opened, audio part only can be opened"
Now, I have run the files thru Gspot, all are Xvid files. I have reinstalled the latest Xvid drivers (v1.10 final), whilst also having 3ivx and Divx 6 pro on my system.
Any help would be appreciated as I am getting rather frustrated here. If there is a tut or guide somewhere that explains how to fix the above, I'd be most thankful to get my hands on it...
Cheers
Madman -
@Flamingmadman:Don't go grave robbing (waking up old threads) - start a new thread - it's really easy!
To address your q: In those circumstances, I'd try loading the AVI in VirtualDub, and frameserve to TMPGEnc.
/Mats -
Thanx for the advice Mats, I'll give that a go
And sorry about the grave robbing
TMPGEnc won't recognise avi, ConvertXtoDVD no subtitles!
By CaptainChaos in forum Authoring (DVD)Replies: 34Last Post: 26th Apr 2009, 11:59 -
Officexp 2002 won't accept my serial to put back MS Word
By abrogard in forum ComputerReplies: 10Last Post: 21st Oct 2008, 01:09 -
Vegas 6.0 Won't Accept mov file
By solarblast in forum Video ConversionReplies: 18Last Post: 18th Oct 2008, 11:17 -
Imac won't accept blank DVD-R DL with Toast????
By dunpal in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 18:04 -
TMPGENC wont accept an mpeg :S
By chocolate_brownie in forum EditingReplies: 4Last Post: 7th Aug 2007, 18:34
