I did a search and found others with the same problem, but no one had a solution.
I have an image iso file. I can open it with DVD Shrink and eliminate the audio tracks and subtitles that I don't want. I only want English. But when I play the movie, the subtitles are on and I have to turn them off. Is there a way for me to force them to be off by default?
I know that if I re-author and just use the main movie title, I can right-click on it and Set Default Streams. But that option isn't enabled when you're backing up the full disc.
Results 1 to 13 of 13
I can turn the subtitles off on the dvd player. That's not the problem. But since I'm the one that is modifying the ISO that will burn to the DVD, I'd like the subtitles to be disabled by default.
...or use Reauthor mode in DVDShrink.
/Mats -
I use Shrink in Re-Author mode to keep just the main movie and English subtitles. If I am starting with a Region 2 PAL DVD, the final Shrunk backup plays perfectly. If I am starting with a Regio 1 NTSC DVD, when I play it back the subtitles are on by default and have to be turned off on the player (Sony DVD/VHS combo). I have absolutely no idea why this happens but it does.
Whether this is relevant or not I don't know, but I thought it worth throwing in to give a bit more info. -
Originally Posted by AngusMacGyver
Originally Posted by hech54
/Mats -
Turning subtitles off by default using PGCEdit:
https://www.videohelp.com/~r0lZ/pgcedit/third_party/2cool/subtitles/subtitles_off_default_pgcedit.htm
It could be however, as MOVIEGEEK said earlier, that you have your DVD player set up to play subs by default. My player has such a setting, and when On, they play, and when Off, they don't, unless I've turned them on by default in the DVD's menu. You might look for such a setting in the Setup Menu of your player. -
Originally Posted by manono
If I use re-author mode, how do I keep the DVD intact? I don't want to make any changes other than to remove some audio and subtitles.
On the right side, I see:
VTS 1
VTS 2
Title 1
Title 2
If I move the Titles over, I get no menus. If I try to move the VTS entries over to the re-authored DVD, I get a long error. The highlights are:
DVD Shrink cannot retain menu functionality when you re-author a menu. Instead, all menu buttons will be removed, and the menu will be converted into a regular video clip. -
Then your only option is to edit the IFO before burning to disc with IfoEdit or other similar app.
/Mats
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
Default Subtitles?
By lamprey in forum Blu-ray RippingReplies: 7Last Post: 8th Oct 2011, 21:49 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 19:21 -
DVD Shrink subtitles
By juststarting in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 19:01 -
Subtitles missing after using DVD Shrink.
By siuol in forum Authoring (DVD)Replies: 5Last Post: 30th Jun 2008, 21:40
