Where can I go to learn about what these are for? It is kind of hard to search for so I apologize if it has been asked already.
Videohelp has a glossary for the most common video terms. Here you go:
https://www.videohelp.com/glossary
https://www.videohelp.com/glossary?I#I%20Frame
https://www.videohelp.com/glossary?B#B%20Frame
https://www.videohelp.com/glossary?P#P%20FrameDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I, B & P frames are what make up a GOP sequence in an MPEG stream. Most editing & authoring software only lets you make cuts and add chapter points on an I frame, which is a full frame, rather than B and P frames which are like partial frames that have part of the previous frame and reading ahead to the next frame in the sequence. The better editors will let you make frame accurate cuts on any frame. This is a plus for editing MPEG streams as it gives you better control of where your breaks are and helps eliminate audio sync problems. You can control the number and sequence of frames within a GOP with the better encoders, telling it how many B or P frames to read agead before the next full or "I" frame in the sequence. The cheaper encoders don't give you that kind of control over it, and some even output nothing but I frames.
I used to have a link somewhere that goes into detail on this stuff but I can't find it at the moment. I'll see if I can dig it up."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 09:24 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
