I ran a file through AutoGK and the output file has no sound. Any way to fix this?
The file is a VOB ripped by DVD Decrypter.
I tried running the IFO file through instead, but I got the same result and there is no sound. -
Thanks, This helped brining back the voice but I am not able to understand if the video is ahead of voice or vioce is ahead of video!!!
Where to begin
1. Don't hijack other people's threads, begin your own. Especially when your post is unrelated or only tenuously related to the original thread. (Note : using the same tool for a different purpose does not relate your problem to the OP's)
2. VCD is a specific standard for authoring mpeg-1 video for playback in VCD enabled devices. See What is VCD (top left corner) for details.
3. AutoGK does not create VCDs.
4. Your version of g-spot is hopelessly out of date. Update it to get more and better information about your videos.
5. The Xvid you are showing here has MP3 audio, so AC3 Filter won't help you in the leastRead my blog here.
Sound doesn't convert using AutoGK
By Looler in forum Video ConversionReplies: 6Last Post: 25th Sep 2010, 21:40 -
No sound in AutoGK output file
By -phenom- in forum SubtitleReplies: 1Last Post: 7th Sep 2010, 09:52 -
AutoGK encodes without sound
By eliserh in forum Newbie / General discussionsReplies: 14Last Post: 12th May 2010, 04:07 -
Confusion about AutoGK, delays, A/V sync issues, etc.
By takearushfan in forum DVD RippingReplies: 11Last Post: 13th Jan 2010, 19:07 -
AutoGK and 5.1 sound
By WebMaximus in forum DVD RippingReplies: 3Last Post: 27th Sep 2008, 08:01
